Results 1 to 10 of 15
Thread: shift kit, Transgo hd2
    Aug 2005
    Spring, Texas
    I just ordered 2nd and 4th gear servos and the HD2 shift kit, so i went to a local dealership to get pricing on install and the tech guy said man that kit will be too harsh for your application! I said everyone i know on ls1truck.com has them, but anyway can yall look at my sig and see if it will be too much, I am going to have the shift kit done by a buddy of allen's at a dealer in San Antonio then have it programmed by allen.
    What do yall think? I just want to squeak a tire in 2nd
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    THat should get you chirping your tires.
    Jun 2004
    george west texas
    this is what all i put in my tranny before the radix and i only put in 1 washer and it barks the tires in the 1-2 shift easy:
    TRANSGO 4L60E HD2 SHIFT KIT
    700R4 4L60E BILLET 4TH SUPERIOR SUPER SERVO CORVETTE
    700R4 4L60E BILLET SUPERIOR SUPER SERVO
    TRANSGO 4L60E SEPARATOR PLATE 96UP TRANSMISSION LS1 LT1
    4L60E FORWARD CLUTCH ALUMINUM ACCUMULATOR PISTON 4L65E
    4L60E 1-2 ALUMINUM ACCUMULATOR PISTON SMALL PIN 4L65E
    SERVO RELEASE CHECK VALVE 700R4 4L60E / CORVETTE ETC
    LUBEGARD TH350 TH400 700R4 2004R AOD 727 4L60E 4L80E
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    I did all that plus the pinless 1-2 and 3-4 accumulator pistons, brown super duty 1-2 and 3-4 accumulator springs. I installed all the appropriate springs that come with the shift kit while I had the transmission apart. I can't wait to see how this thing shifts. I installed red alto clutches and steels and the 9 friction plate 4th gear clutch pack to I can tow or haul ass in 4th gear without worries. Oh yeah, kevlar 2nd gear band, too.
    Aug 2005
    Spring, Texas
    sounds good, but will this be harmful to my tranny?
    The servos will improve holding power which should improve the life of the clutches. The transgo shift kit will help fix common problems with the 4L60E.
    Aug 2005
    Spring, Texas
    Is there anything else i can do while i have the hd2 and the servos installed?
    A larger transmission pan and an external tranmssion cooler to bring the temps down. Be sure when you plumb in an external cooler that the cooler input is the output line from the radiator so that it will cool it further down than the radiator water temperture. It doesn't do much good to cool it down only to send it through the radiator to heat it back up again.
    Aug 2005
    Spring, Texas
    yeah i had planned on getting a new tci oil pan w/2quarts more and a B&M cooler behind my grill. I will just have to move my exhaust from under the transmission.
    Thanks man, you were a big help.
    Good luck with the new accessories!
    On a side bar, I went down and met the owner of Rock-ontransmissions.com today. Pretty nice guy. He builds HD transmissions or rebuilds stock units of any type. His specialty seems to be the 4L60/700R4/4L65/4L80Es. He told me some of the things they do to make the unit indestructable. It sounds to me like he really knows his stuff. I think he said that he had a 4L60e unit up in Maine or somewhere like that, behind 1050+ hp LS1 and it survived 27 passes at the strip! Damn, that sounds strong. The guys on LS1Tech speak highly of his work. He ships his transmissions worldwide if anyone ever needs a good strong unit.
