Results 1 to 3 of 3
Thread: Need Some Help?
    Oct 2005
    Ok guys, me and a mechanic friend of mine just installed the vette servos in my 2002 rcsb Z-71 today. After we got through he took his tech 2 and cleared the taps on my computer to help it relearn the shift points. Now I have a question. When you go Wot it will make a squeal/squek sound on the 1-2 shift. Also it is extremely hard shifting(1-2) in tow haul. He said that this would go away in a 100 or so miles. Does this sound right to everyone? Could this hurt anything? Please give me some help here anyone!!
    Oct 2003
    Houston
    Not sure where your squeak is coming from but in my truck WOT and tow/haul i had a belt that would slip or something and make that kind of noise. After changing the belt it never came back.
    99 Pewter SCSB
    DJM 4/6 drop, Hotchkis front/reat swaybars,Hypertech power programer, milled & built heads, Accel wires, distributer,coil, Mass Air Flow Sensor(mti motor sports, Granatelli),Dynomax UltraFlow Stainless, 17x8.5 Eagle Alloys, Escalade door handles, Suburban front grille, with clear corners and billet bowtie,Street Scene mirrors, Cowl Hood
    Did he use a gauge to check the 2nd gear band apply pin adjustment? Too loose and it could be the band slipping. If all he did is replace your stock parts with the Corvette parts, the manufacturing tolerances may be loose enough to affect the band adjustment. Hopefully he didn't install any shims/spacers that would limit the amount of piston and pin travel.
