Results 1 to 10 of 11
Thread: lowwww
    does anyone know where i can get a decent lowering kit? maybe like an inch in the front, and 2 inches in the back? if i got that would it make the truck look even instead of the back end looking kicked up?
    Jegs or Summit has about the best prices I have found. McGaughys makes the best engineered products if you want spindles. If you only want 1" in the front you can go with a coil. 2" lowering in the rear can be done with a simple shackle. If you just want to level it out, go with the shackle only.
    Jul 2005
    modesto, ca
    I don't know of any company that makes a 1 2 drop. You can get two inch Belltech lowering shackle, a buddy of mine went that route, it looks good. But a Hotckis 2 4 drop suspention kit would look sweet and make it handle like it was on rails, the kit comes with front + rear springs, front + rear sway bars w/bushings. It will still ride decent, I hear that any lower than a 2 4 gets rough. Thats what I want to put on my truck.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
    Jun 2005
    Round Rock
    If you want level get the shackle only. If you go 2/4 make sure you ask them if you need to shim the rear axle and what it will take to do that.
    Aug 2005
    Spring, Texas
    I ahve a 2/4 drop on mine, i live on rough roads and it rides like it doesn't have tires on it sometimes, but on the highway you wouldn't be able to tell that it was lowered.
    06 TrailBlazer SS LS2 4.10's
    02 SC StepSide Factory Orange
    Full Bolt-On 370 - Little Cam- Victor Jr Intake -Worked 5.3 Heads - 4.56's - Built 60E - Circle D 4000
    07 CTS-V CAI, GM Performance Exhaust, Ported TB, Coil Overs
    does anyone have a pic of thier truck with a 2-4 drop on it? also how much does the actual hotchkis kit cost? guy i used to work with said, if i wanted rims, i should get those first before i do any kind of lowering, because if i want certain rims, they may not fit.
    Sep 2004
    My truck as a 3.5/4 drop on it. I don't know if you remember it from the track the other day.
    The rear height is just right, but my front end is too low for practicality. If you lower the front with a spindle it will ride just like stock. I would buy the McGaughy spindle for the front. That will lower the front 2 inches which should be perfect.
    Ross
    No more trucks, but this is what I used to have. 2000 GMC Sierra, 6.0L-LQ4, Built 4L60, LS6 Cam, The Other Guys Headers, 3 inch exhaust and 7 chamber flowmaster, 43lb injectors, Nelson Tuning, Drop - 3/4 McGaughys Spindles, Bell Tech Shackles & Hangers. Best time 13.59 @ 106
    yeah i remember your truck from the track ross. i really liked it, but i dont think i could see myself in something that low. so what, a set of spindles to get it two inches lower in the front, then what about the back?
    haha why dont i just start cutting springs, so my front tires bow in so much that the inside walls of my tires get rubbed down first, and then i can write my last name "fuentes" on the back in old english letters nah im just kidding.
    Jun 2005
    Morehead City, NC
    Belltech makes as low as 1" block for lowering rear.
    '07 Trailblazer SS 1SS 2wd. Jet-Hot Kooks & cat'd Y, Mufflex catback, Taylor TV 50's, TuneTime-Westers, CAI, new e-fans/160 stat, pulleys, built 4L70 & Vig 2800, trans cooler. Window tint soon!
    David-Morehead City, NC
    ############################# http://i177.photobucket.com/albums/w...tb/TBSS4-1.jpg ##############################
    Jan 2005
    Humble/Houston TX
    i heard that if you swap in a OBS coil spring up front it will drop it 1". anyone else hear that?
    old mod list: H/C/I/N/E/G 408
