Results 1 to 10 of 17
Thread: questions for those that used Lextechs 411 wiring guide
    Sep 2010
    I trying to get a better understanding of exactly what needs to happen on the wiring side of my upcoming LS swap in my 98 Tahoe 4x4 and I have a question for those of you that have repinned your OEM harness for use with the 411 PCM.
    did you reuse the wiring from the OEM injector connector and just add individual coil pack connectors to it or did you remove all those wire from the harness and start new ones from the 411 PCM?
    Jan 2014
    Las Cruces NM
    Just to avoid cutting and splicing, I removed the coil wiring and the injector witing from the donor truck harness and loomed them into my trucks factory harness. They were plenty long and now I dont have spliced wires. Just how I did it but would work just fine either way.
    97 RCSB . 2WD . 5.3 . 4l60E . E-FANS . PNP 706s . TSP 228R . 3600 STALL . HD2 . VETTE SERVO . 3.73s . 2" DROP
    TURBO IN THE WORKS
    Sep 2010
    so where did all the wires go from your OEM harness that once went to that big injector plug on the Vortec engine? Can they all be removed from the harness or do I need some or all of them for other things now?
    Also, does anyone have any feedback on what happens with the EVO sensor on the PS pump? My truck has this steering assist sensor and Im not sure where this would now tie in to the 411 PCM
    Jan 2014
    Las Cruces NM
    I just removed them completely. But if your not adding any new wires from the PCM you just need to splice into the original injector wiring which will work out just the same. You'll just be using those wires for the injectors nothing else.
    The power steering plug can just be left unplugged if your going with the LS donor ps pump. Nothing will happen at all. I did just that and glad I don't have that variable power steering anymore
    TURBO IN THE WORKS
    Sep 2009
    NE Ohio
    I cut off the big injector plug and had my injector wiring already inline on the motor and soldered the old to the new. I got lost with Lextechs diagram and ended up running a lot of the LS plugs and wires directly to the PCM. I got overwhelmed and I will definitely do it differently next time.
    Been lurking since 09 and I finally have my kickass 6.0 LQ4
    LQ4 LQ9 6.0L Engine Service Manual Save to your computer in case it disappears
    link to said diagram?
    97 xcab c1500 lm7 5.3 swap 343RWHP 329RWTQ 13.40 @ 101.97 2.03 60ft. MODS: Longtubes, 3200 stall, TR220 112lsa, .030 799 heads, NNBS intake, PTM 92mm TB. 4" PVC "hot" air intake 3" single exhaust w/cutout 3.42:1 gears, 29" tall tires. Dyno tuned by flaco
    Sep 2010
    Quote Originally Posted by capricefrk013 View Post
    what would you do differently? Would you use Lextechs diagram or use the GEN 3 harness and PCM along with the stock PCM?
