Help!! Clutch pedal hard as a rock on ls1 c1500 5 speed
So I was bleeding my clutch today and when I was. pumping the pedal it got stiff. I told my friend to bleed it and it got soft but as soon as he tightened the nut and I started to pump it, it got stiff as a rock again. What could it be? Slave cylinder is new, would i need to shim it? Feels like the slave is long thanks!
- You may not post replies
- You may not edit your posts
