Results 1 to 9 of 9
Thread: Help!! Clutch pedal hard as a rock on ls1 c1500 5 speed
    Jan 2014
    What clutch do you have?
    Quote Originally Posted by LOWnEASY View Post
    Zooms performance clutch. It has part#1377c throwout bearing.
    And it has a 4.8 flywheel.
    Jan 2014
    Is it so stiff you can't push it in or just really firm?
    Sep 2010
    N FL
    Make sure the connections are pushed in tight and locked! If the line to the slave is not snapped in good to the slave it will be hard like u explained! Good luck!
    Quote Originally Posted by 1BAD6660 View Post
    Ill take a look thanks!
    I cant push it in more than halfway it just gets really hard its like something is in the way.
