1994 GMC Sierra SL 4X2
4.3L V-6 Auto
Sorry this is so long, but here it goes....
I recently have been having some stumbling issues. On the way to work the other day the truck just died on me at a light and was hard to get started. Then engine would turn over but just wouldn't start up and run. After a few moments I was able to get it to run and "limped" it into a parking lot. It was raining like crazy so I didnt get a chance to pop the hood and do a visual. After waiting several minutes I was able to start the truck again but had to stay on the pedal to keep it running...it just would make it at idle. I made it to work and let it sit till my first break. I checked it out and it cranked right up and seemed to perform well except under a moderate to heavy load.
I changed my plugs and wires today (Bosch plat. plugs gapped at .043 / Accel 7MM wires) The truck seems to run a bit better but still weak under load. It feels like I am pulling a huge parachute behind me not allowing me to gain speed. I also changed the oil added a new air filter and filled the truck up with 93 pump thinking maybe this would help..still no go![]()
The only way I can describe this is that the truck hesitates and bucks. I can easy her out the drive and slowly gain speed if Im not attempting to accelerate to fast. I mean Im getting blown away by Kia's here and they arent even trying..LOL
I pulled codes 32 and 44 from my GM diagnostic thing -a-ma-jigger. The book says :
32 - Baro switch / EGR valve
44 - Lean exhaust indication, o2 sensor voltage stays low after 1 or 2 minutes of engine run.
In addition, FYI...I had my fuel pump replaced a year ago. After a few months I noticed I was having a strong fuel smell at the fuel tank (raw fuel). There is no leakage if it sits, but I was told by a couple peeps that when I take off under moderate acceleration, they see some liquids dropping from where the gas tank sits.
I am requesting some insight in what the potential problem might be. Also if these 2 listed parts above are needed what is an approximate cost of each and wheres a good place to shop?
Thanks in advance for your help.![]()
