Results 1 to 10 of 18
Thread: Heads up, engines for sale soon
    San Antonio, TX
    hey guys, just a preview, been doing some business with a supplier, got some engines that are coming up for sale.
    misc stuff, all good stuff, new to lightly used, zero to low miles, mix and match.
    we got:
    454 bbc
    HO 330hp 5.3L's
    6.0L HO and LQ4's
    6.2L LS3's
    6.2L ZR1 63xhp
    ZL1 6.2L camaro supercharged
    6.2L LSA supercharged
    6.2L 565HP supercharged truck engine (hmmm)
    Arizona/Utah
    Shoot me a quote for a LQ4 when they start rolling in.
    All Gen IV stuff?
    Are you just getting complete engines or will you be getting short blocks/long blocks? I would definitely be interested in either a 5.3 or one of the 6.0's
    San Antonio, TX
    ya, only gen4 stuff, the older gen3 stuff have too many miles and the newer engines go right in with just a few tweeks.
    pm what you're interested in and i'll see if we have something.
    we have complete and misc parts, just depends.
    Jan 2012
    Baytown, Tx
    PM sent for gen3, but will the gen 4 stuff work with the dbc tb?
    2015 Yukon SLT
    2000 RCSB 6.0/4l80e
    1967 Chevy II 5.3 w/ 76mm snail
    San Antonio, TX
    Quote Originally Posted by N/ALS1 View Post
    gen4 engines will go right in place of a gen3 engine with no problems. we're doing them all the time.
    all you need:
    tap sides of block for old style knock sensors
    use the lingenfelter cam/crank box
    use a 3 to 4 bolt throttle body adaptor, if needed.
    depending on what you get, a vette filter used on single fuel rail setups.
    the problem with the older gen3 stuff is, it's older and they usually have high mileage, all this new gen4 stuff we're getting has only been used for test firing and quality control, emissions testing, new pull outs, and zero to low mileage, low mileage meaning under 3,000miles, and that's on the high side.
    Oct 2011
    San Antonio TX
    X2 but gen 4 6.0 of course.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    damn, I'd love one of those s/c truck engines. Want to trade for a 9.5:1 408? I would even take an LS3 off your hands.
    Want an l92?
    with under 3000 miles?
    I'm holding out for a 454LSXr from scoggins-dickey
