Motor Mount ?
Been searching on here for an answer, but every build is different! I have an 88 GMC I'm converting over to a 6.0l 4l80e, what I want to know is what mounts to use? I already have the Trans Dapt adapter plates 4572, but they are for the stock location. From what I have gathered I need the plates that move it back 1" so I dont have issues with the tranny bolting up correctly on the crossmember, and driveshaft issues. This correct? Someone whose done this please chime in, Thanks!
- You may not post replies
- You may not edit your posts
