Results 1 to 10 of 16
Thread: lq4 swap won't run for more then a few seconds
    hey guys, I have a 70 c10 I just put an lq4 in. it has a cam, long tubes, and typical supporting mods. I'm running an aeromotive fuel pump and bypass regulator into FAST fuel rails. the PCM has been tuned by Nelson. the problem is, it starts, but dies after 2 or 3 seconds. I was hoping someone could help diagnose this or point me in a direction. thanks in advance
    Dratically losing fuel pressure, or VATS
    San Antonio, TX
    check fuel pressure, unless it's a corrupt pcm, it def won't be vats, we turn that off for sure.
    pm your name and info, we'll compare notes.
    btw, fuel pressure should be 55psi or so. what did you set it for?
    Nelson tuned it and they knew it was a swap, but maybe they didn't eliminate vats? and as far as I can tell, the regulator stays strong at 58 psi. but, as soon as the pump shuts off, pressure drops immediately. should this happen?
    Dec 2010
    Quote Originally Posted by Silverado889 View Post
    The pump shouldn't be shutting off... but yes, the pump shutting off should definitely result in a loss of fuel pressure...
    Quote Originally Posted by Wagonbacker9 View Post
    Actually, shutting the pump off should result in a loss of fuel pressure over an extended period of time... not instantly by any means. My truck will still be holding 50+ psi after 5 minutes of the truck being off.
    Dec 2011
    London, Ontario, Canada
    This is with the truck not running. His pump shuts off while the truck is running so the injectors will keep pulsing causing pressure to drop in the rail until there is not enough pressure to supply fuel. It sounds like an issue with either the PCM or VATS to me.
    Sep 2011
    Fuel pressure regulator?
    regulator is an aeromotive bypass regulator, set at 58 psi. this is a new swap, and hasn't run yet, so could there be other possibilities also?
    blew a hole or have a leak in the fuel line between the pump and the tank metal fitting.
