Results 1 to 10 of 21
Thread: 2000 v6 4.3 conversion to 05 v8 5.3 need help on wiring
    Mar 2012
    nothwest houston
    just recently stared doing the swap on my 2000 silverado and finally got done installing the motor, now got some of the wiring done but rand in to some problems like some of the connectors dont match up, like the tranny elctrical conector the one on my tranny is a circle and the one on my new harness is an oval lookin one, also in the fuse power box i have extra connectors that i would like to know where they go i will post picturs soon please help
    Welcome to the site!!!
    The fuse box connectors, are they big rectangles or squares with a bunch of wires coming out of them??
    Mar 2012
    nothwest houston
    thanks man
    Mar 2012
    nothwest houston
    i have on the new harness a white connector that looks it goes to the blue one but they dont line up right under the fuse box pannel ill will try to post picture tommorrow
    What year is your harness? There's quite a few guys on this sit that have done the swap. Myself included.
    Mar 2012
    nothwest houston
    the harness came from a 05 chevy work van with the motor, i was able to connect the basic plugs.its came down to the wires going to the main fuse box in the engine bay, i not sure if i need to get the smae year fuse box that came with that motor or is there a way around that if you have any tips or advice i would really appreciate it
    You need a 99-02 truck harness. That's it. No if, no buts. 99-02 truck harness.
    if it started and ran for two seconds and then died you most likely need to have the VATS/Passkey disabled in the tune.
    Nov 2011
    just do a relearn and you should be fine..
    Jul 2012
    I've been told you don't want to start with a v6 platform, is this true or people just being afraid of it?
