Results 1 to 10 of 30
Thread: coolant temp sensor question
    Feb 2011
    Fort Worth Texas
    My 1990 obs sensor has the exact same 2 wire connector that my 2003 5.3 has. Can I just use the 5.3 sensor and have my temp guage work properly or do I need the adapter?? I ordered p/n 182-2277 adapter from speedway motors but it has a 1/8 female end and my obs sensor has very large male threads, I'd say maybe 3/8ths. Any adapter to accept my obs sensor would seem to have to be very large???? I'm stumped. Thanks.
    Do like the other guy that posted yesterday, go buy a 1/8"NPT to 3/8" NPT adapter. Issue done. Use your old sensor since the resistance values in sensors change over the year models.
    Dec 2004
    San Antonio, TX Area
    I just drilled and tapped the water pump.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Feb 2011
    Fort Worth Texas
    Thanks for the input guys, but I'm still confused as my obs sensor has gigundo threads,much larger than the oil sensor.I don't know if anyone has done this but I could drill and tap the original location in the head,but the heads are already on and I don't want to botch it up. I'll check around for other adapters though. Thanks again.
    Jan 2012
    warwick ny
    You ordered the adapter for oil pressure sensor.Check out this thread he shows the adapters with part #'s http://www.ls1truck.com/forums/lsx-t...ed-swap-3.html
    Jun 2009
    Caledonia, MI
    You have the 3/8 sensor just like me.
    Jul 2010
    Douglasville Ga
    Ect signal is a huge input used for fueling. Gotta have it. A temp sender is different than a temp sensor. You need a sensor for the pcm and a sender for the guages.
    Street and Performance sells the exact adaptor you need. Metric to 3/8 pipe thread. Only thing that sucks is that they're polished. Yuck! Lol
    Sep 2011
    Atlanta Ga
    Quote Originally Posted by vortecyota View Post
    i dont even know where the pigtail is on the harness..smh..anyonehave an extra one? also what pin does it go into the pcm?
