Results 1 to 3 of 3
Thread: 1/4 MILE TIME
    Mar 2005
    I finally ran my truck last night. the tire were stock truck tires pretty much slick as a ribbon so i spun for a long distance and i did not use any nitrous. M y truck is still cutting out so i am taking it to the nearest dyno place aorund here to get the final touches on it before i run it with drag slicks or even nitrous
    60- 2.1
    1/8- 8.6
    mph- 83.64
    1/4- 13.4
    mph-102.28
    all motor no bottle
    2000 RCSB SS 2WD 6.0L LQ9 4L60E
    LS6 INTAKE, MSD WIRE, 80MM BBK THROTTLE, AIR AID THROTTLE BODY SPACER, BODY, 80MM SLP AIR METER, 36LBS INJECTORS, LS1 ELECTRIC FANS, YANK 3200 STALL, 4.10 GEAR, FAST FUEL RAILS, COMP CAM .224 .230 .581 .592 114LSA WITH 918 SPRINGS, PACESETTER LT HEADERS, 3" EXHAUST DUAL SUPER 40 FLOWMASTERS AND CUTOUTS, NELSON TUNE, SLP 160 THERMOSTAT, THROTTLE BODY BYPASS AND NO EGR OR CATALYTIC CONVERTERS.
    4L60E WITH STAGE 2 SHIFT KIT AND VETTER SERVO
    FUTURE MODS: STAGE 2 HEADS, SUPERCHARGER, UNDERDRIVE PULLEYS AND A 6 SPEED TRANS
    5.6 in the 1/8 mile? damn, you must have about 900hp under the hood!
    That's really good times there. Maybe an 8.6 in the 1/8th?
    Congrats!
    Mar 2005
    my bad there was a typo it was a 8.6 not 5.6 in a 1/8
