Results 1 to 8 of 8
Thread: Ls1/ls2 frankenstein?
    Jun 2011
    Clarksville, TN
    What do u guys think about this: my bro has an 05 c6, and he's getting a entire top end kit from vengeance racing, basically replacing from cam on up....he's giving me his stock ls2 parts from the vette. My truck is an 06 4.8L, typical bolt ons and tune....i checked around and his ls2 parts will bolt on my motor with no mods neccessary...what do u think the increase in hp/tq will be? im looking for advice and opinions here. parts that he's giving me are: cam, pushrods, complete 243 heads (stock), intake manifold, throttle body, all from his 05 c6 vette. Will my tuned ecm run this for awhile til I retune it?
    Oct 2011
    Quote Originally Posted by demonheavymetal View Post
    first things first, a 4.8 is not an LS1. lol sounds like a pretty sweet deal though! I'm sure you'll definitely feel an increase in power!
    Pittsburgh, PA
    youre going to drop compression, the ls2 cam is same as the 01 Ls6 cam. Ls2 intake will lose you bottomend vs the truck one. If you mill the heads then it will benefit from it
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jun 2011
    Clarksville, TN
    Quote Originally Posted by qwk_snd View Post
    Ok yes, its iron block smaller bore n stroke make it an LR4, but its basically an ls1 (based off same design). Stock cam specs on the vette are 204/211 mid .500s lift so im considering a diff cam, but cant beat FREE 243 heads.
    Jun 2011
    Clarksville, TN
    Soi shouldkeep my truck intake on n just use the heads, what about the tb?
    Apr 2006
    Bellevue, Nebraska
    Pretty sure you'll need an f-body water pump as well. Or mod the truck upper neck.
    Jun 2011
    Clarksville, TN
    Quote Originally Posted by AFSP1211 View Post
    Your right, I forgot about the water pump....im goin to check on that. Thx
    Oct 2011
    San Antonio TX
    My 07 4.8 has 243s stock.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
