Results 1 to 8 of 8
Thread: Ls1/ls2 frankenstein?
    Pittsburgh, PA
    youre going to drop compression, the ls2 cam is same as the 01 Ls6 cam. Ls2 intake will lose you bottomend vs the truck one. If you mill the heads then it will benefit from it
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Jun 2011
    Clarksville, TN
    Soi shouldkeep my truck intake on n just use the heads, what about the tb?
    Apr 2006
    Bellevue, Nebraska
    Pretty sure you'll need an f-body water pump as well. Or mod the truck upper neck.
    Jun 2011
    Clarksville, TN
    Quote Originally Posted by AFSP1211 View Post
    Your right, I forgot about the water pump....im goin to check on that. Thx
    Oct 2011
    San Antonio TX
    My 07 4.8 has 243s stock.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
