Results 1 to 3 of 3
Thread: tranny
    Dec 2004
    I'm having trouble with my 03 4.8 silverado tranny slipping in 2-3 shift. got 65k. it's slipping in and out when it shifts but it's only when it goes in 3rd. i just did a filter change and put 5 quarts in but not sure if it's the fluid level. also having problems slipping when making a hard left or right turn, any help would be greatly appreciated.
    you're quite low on fluid I bet. You are checking the fluid hot, in park, on level ground with the engine running I assume. You may have to wipe the dipstick a few times to double check the level. Be sure it has the same amount of fluid on both sides of the dipstick.
    Apr 2005
    Saint John, MO
    RedHeartbeat is right. The refill/check procedure is actually kind of involved. There is a section about it in your owners manual. The bottom line: fluid must be hot, read both sides of the dipstick, add a little at a time.
    Oh yeah, you're supposed to shift through each gear range, then into park, while idling, just before checking the dipstick. Something like that. Check the manual.
    Good luck.
    Base: 2004 Victory Red Silverado 1500 2WD RCLB, LR4, 4L60E, 3.73, HD Suspension, P245/75R16 Tires
    Mechanical/Performance: Nelson 93 Octane Tune (See Slamma's CarDomain.Com Page for more details)
