my insterment cluster isnt working anymore, also the cruse control. the green turn signal lights work fine but everything else isnt working all the sudden. i think it could maybe be a relay but idk what one or anything... thanks for the help guys
Built 2 Run! 6XX HP/ 6XX TQ
Start checking fuses and grounds. I can't imagine the whole thing going out at once.
well the cluster will go out every now and then. and i tap on it and it will work now its not working at all... about a week ago all the fuses were fine?
Check All the fuses and grounds.
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
I would also check the connections at the cluster, because it sounds like a connectivity issue if you could tap it and get it working again before. I would look for loose wires or a dirty connection somewhere.
i checked that big plug in he back and blew it out and sprayed elc cleaner on it. i know my cluster is not working, neather does the cruse control. and also some times the climate contorl wiggs out.... i know its got some weird issue somewere but the fuses look good and the plugs clean?
