Results 1 to 4 of 4
Thread: Oil pan modification
    Oct 2011
    San Antonio TX
    Does anyone know a shop or person that can modify a factory truck oil pan. We are stickin a 5.3 in a 91 olds bravada. The only reason is because the litte suckers all wheel drive with very little room for anything but the stock v6 pan. Pretty much a Typhoon with 4 doors. In San Antonio or close by would be nice.
    Sep 2010
    McPherson KS
    if the only problem you're encountering is with depth then I would say try either a Corvette or F-body oil pan. That or you could always try and convert to dry sump, but I think an F-body pan would clear the front diff if that's where you're having issues.
    Broken Bow, OK
    Check this link out, surely one of those will work for you. Bust out the tape measure.
    http://www.s10forum.com/forum/f213/l...f-them-324366/
    Or try www.hotrodlane.cc where they have all kinds of custom cut pans.
