Results 1 to 9 of 9
Thread: autometer
    Apr 2005
    i have a trans temp and a water temp autometer gauge anybody have a diagram or any tips on installin em ???? like where to put the temp sender thing they give you like where does it screw in?
    1999 GMC Sierra black reg cab short bed SLE Z71 5.3 <--CARDOMAIN PICS
    NELSON 93 hot tune, 02 PCM, VOLANT Ram air intake, MSD wires, ACdelco iridium plugs , Edelbrock ceramic shorty headers, jegs off-road y pipe, Dynamax int pipe, 3" Magnaflow Exhaust with turndown, EGR removal, throttle body bypass, vette servo, long servo pin, performance 4th apply piston, B&M shift kit, SLP 160* thermostat, LS1 Fans, NELSON harness, ported and polished throttle body (did it myself, for free lol)..... _______? cam is next as soon as i stop spending all my money
    San Marcos Texas
    If it will work there is a hex plug in the right rear head that you can install the coolant temp. You might need to install a "T" into the transmission cooling lines to screw your sensor into. Just some ideas.
    Apr 2005
    right meaning passenger side?
    San Marcos Texas
    Yes.
    Apr 2005
    ok im all set witgh the water temp but what about the trans temp thats what i realy need some help with&#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33;&#33;? ???????????
    You can buy an transmission drain plug kit to put in the pan. It has a 1/4" NPT plug, I think. Instead of having the plug in there you could screw the sensor in it&#39;s location.
    Apr 2005
    my transmission hasd a drain plug already any other way to hook it up???? thats the only thing im havin trouble with
    If the plug is in a location that would not put the sensor in harms way, replace the plug with the sensor.
    Apr 2005
    the plug is on the bottom of the panand its recessed a litle bit its an alan bolt i dont do any offroadin or anything so im not gonna smash it on anything but will it have enough clearance from all the internals of the trans once its in there? just checkin
