Results 1 to 10 of 11
Thread: Suggestions on how to make my new LQ9 last
    Mar 2011
    Gibbstown, NJ
    I have a NEW....haha NEW LQ9 coming from GM, i have a few other post on here and i run a decent list of mods, soo i would like some input on how i should go about breaking in this engine before something the bed again like last time. So should i break it in with the turbo on or disconnected, should i cam it right out of the crate, and if soo how should i do it and when should i install the turbo back on if i decide not to install the turbo on it during break in
    ? any have any problem like this please let me know what you did and what type of combo you were running and what spark plugs would be tter for turbo and non turbo applications..
    Thanks
    Slim
    2001 ECSB Z-71: 7.0L LS7, Kook's LT's, True Duals, RPM Tune, F.A.S.T. Intake/TB, YANK TT3000, 4:10's, G80, AWD Swap, 160-Stat.....
    Slowest in South Jersey ..........SOLD :-(
    2012 GMC Sierra Z71 CC: 6 Speed, 3:73's, G80, Back up DD...........SOLD
    2000 RCSB Shitbox.......370LSx/Built 60e/4.56's,EATON Posi, CAI,3" SLP Exhaust, DD.......Build Thread http://www.ls1truck.com/forums/my-ga...ker-punch.html
    seriously, get a live tune on it once you get it together if you're going to run more than 5 psi. Make sure to monitor the fuel psi while driving. Many suggest you go to a return style fuel system with a boost reference fuel pressure regulator, if you don't have that already.
    Mar 2011
    Gibbstown, NJ
    I have,the return style type fuel rail with a rail mounted factory psi regulator, thay I was told will reference boost
    I would do everything right out the gate, put it in the truck and have at it.
    Ponca City
    A wise builder told me on the first startup take all the sparkplugs out and turn it over until u have oil psi. Then put the plugs back in and start it. But just my .02
    Slowest in Oklahoma...
    Mar 2011
    Gibbstown, NJ
    sounds like good advice i will def do that....btw nice ride in your avatar
    Quote Originally Posted by ecld_07 View Post
    When I did my cam swap I was told to unplug the main connector for the coil packs. That let the motor turn over and get everything moving around. After about 30sec of turning it over we plugged the connectors back in and it fired right up like there was never anything done.
    Ponca City
    Sounds like basicly the same concept except mine doesn't build compression and push down on the dry bearings as hard. Either way is better than just starting it up to me
    Jun 2011
    Rogers, Ar
    It's better to disable fuel so you don't wash the cylinders down...
    I like the spark plugs out for no compression idea. Wish I had a fresh motor to try it on
    Mar 2011
    Gibbstown, NJ
    I have a fresh hi-perf 5.3 thats almost done for someone to come and start up
