Results 1 to 5 of 5
Thread: 97 Truck with 5.3-based 383 stroker swap - Which tranny?
    Aug 2011
    Houston
    Question 97 Truck with 5.3-based 383 stroker swap - Which tranny?
    I've been doing research for the past few weeks on this and I'm still a little uncertain about what path I should take with the tranny.
    Truck is a '97 Suburban K1500.
    The new motor is an '04 5.3 converted to a 383 stroker. Engine should make 500ish hp/tq by the time it is swapped in.
    The truck will be daily driven with mild towing and mild off-road use. No track use. Also there will be no nitrous or boost.
    So, I want a tranny that I can buy, rebuild with performance parts and have it be reliable. I would also need one that I can run with the '04 5.3 ECM and have as little wiring work as possible.
    Which year tranny/tc should I target for? 96-98? 99-05? Can I achieve my goals with the 4l60 or do I need a 4l80?
    Any help is appreciated. Thanks!
    '06 Magnum SRT8 - Daily Driver
    '97 Suburban 4x4 - 5.3 based 383 stroker build in progress
    Mar 2011
    Grand Rapids Mi
    I'd go 4l80 the 4l60 is a little on the weak side...IMO
    +1 on the 80e.
    Spring, TX
    4l80e end thread
    '02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
    2013 GMC Acadia: SLT1 Carbon Black
    1976 Corvette Stingray: Trying to save it, progress is slow.
    ^Ricky's Sweet PS Skilz
    09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
    Aug 2011
    Houston
    ok, thanks for the advice.
    Which year 4l80e should I target for? Can I get one from a '97 K2500? Will it work with the '04 5.3 ECM?
    Does it need to be from a 4WD truck to work for me?
    Also, is the transfer case different from 4l60 to 4l80?
