LS3/L99 conversion
Hey guys, been awhile since I've posted. I'm swapping my LS6 with a 2011 l99 that I'm converting to an LS3 getting rid of the DOD and holding on to the VVT for a later time so I'm going to use an LS3 timing chain cover for the CPS. I just picked up a brand new wiring harness super cheap that will take some modifications for the new E38 ECM. I was wondering what transmission module the conversion guys were using. I know Holden has a 6.0 Lumina with a module that works perfect but I was thinking about using a newer truck or car module and I'll build the harness for it. I'm keeping my 2002 4l60E with 3800 stall and installing new LS7 lifters, a cam recommended by Comp with some broad horsepower, .675 lift patriot spring kit and pushrods. I really just want to know what snags members have run into with the LS3 swap. With the mods to the block and add on's I would like to get close to 500 at the crank. I'm leaving the compression ratio the same instead of the LS3 because it's lower and I found a Roush TVS 2300 to go on top If I decide I need more HP. If anyone has any suggestions I'd like to hear them but in the meantime I'll do some reading. Good to see more new faces on LS1 truck!
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
- You may not post replies
- You may not edit your posts
