Results 1 to 10 of 20
Thread: 862 heads from start to finish... almost lol
    Dec 2009
    houston tx
    here are a couple of pictures i took from start to finish well kinda finish on porting a set of 862 heads. they will recieve a valve upgrade and be flow benched once done
    stock
    120 grit
    400 grit
    600-1000 grit and a mirror finish
    same is being done to the exhaust. this head alone has taken over 12 hrs of work lol
    pic was taken last night
    looks perdy.
    Pittsburgh, PA
    Very nice
    Feb 2011
    cleveland
    I need to send you mine yours looks great. Good job man
    the texture of the tunnel is very important to keep the fuel mixture tumbling. What you have the will lead to puddling and droplets forming, IIRC.
    So should he put the intake back to like a 400 grit texture.
    Pittsburgh, PA
    exhaust is nice to have that smooth years ago when ppl ran carbs the texture was very important, today with the pressures of fuel injection it isnt as critcial
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    I can't wait until they start with direct port injection on the LS series heads. Talk about opening up a ton of HP possibilities. Might need a bigger pump.
    Dec 2009
    houston tx
    thanks guys im almost done with the head im hoping to get at least 260+cfm @ 600lift on the intake and 200+cfm@600 lift on the exhaust
    Dec 2009
    houston tx
    more pictures the exhaust is done now im starting on the combustion chamber
