First pass we ran a 11.5 @ 122mph. 2.06 60'
Second pass 11.2 @ 125 1.9 60' (We tightened up the belt. It was sliping a little)
These two passes were with the charger alone at 14PSI
The second pass we got kicked off for not having a rollbar. So next time to the track we are going to be putting in the 9" and rollbar. Hopefully we can launch for once with a larger pair of slicks and we will probably run some squeeze on top of it.
For the first time to the track we were happy with the results. Now we know what needs to be tuned in and adjusted.
Sean
- You may not post replies
- You may not edit your posts
