I have a 6.0L LQ9 with all NEW LS2 internals, and LS3 top end, This is a Knock sensor in the valley engine.
It will fit 99-07 trucks( direct drop in) All you have to do is extend the MAP wire to the front and tune.
Included:
Used 6.0L Block
New LS2 Crank 24X reluctor
New LS2 Floating Rods And Pistons
NEW Hell Fire Rings
NEW Cleveite P/H Bearings
NEW ARP Head Stud's
NEW SKPP Block Allen And Stud Kit
NEW LS2 Timing Gear/Chain
New LS7 Lifters
New LS3 Rockers With Bases & Bolts
New GMPP HV Oil Pump
New Cam Bearings
New SKPP CAM (Numbers are; INT .525 lift, 218' @ .050 duration, 111'centerline, EXH .542 lift, 230' duration @.050, 122'centerline.)
New LS3 0821 280cc Ported heads (Great for this mild cam)
(hollow stem IN and sodium filled EX)
NEW LS3 Springs
New LS3 Intake With Rails And Injectors.
Vented Valve covers
All Covers Will Be Powder Coated Your Choice Of Color.
(I can get the surp relocate bracket if you need to run it with the truck drive sys. for $30.00 extra)
$3900.00 + Shipping
