Results 1 to 3 of 3
Thread: GM quick connect adapters
    Where can i find the quick connect to AN or NPT adapter fittings? I'm not having any luck locating any.. i just need to get the stock lines and what not hooked to the regulator and the stock stainless rail hooked to AN 8 feed.
    -2005 1500 Z71 ECSB 6.0 swap, Cooks Racing 4L80E, NP261HD, Carolina Driveline 5" shaft, CST Tie-Rods, front mount 76mm, Livernois hot pipes, Circle-D 258mm (~3500), Mallory 2-step, 100 Dry shot, 750CC RC Eng. Inj, Nelson Tuned, 4.10's, all through a STOCK 10-bolt
    Broken Bow, OK
    I got mine from Summit. Jegs has them and I have seen them on ebay too.
    3/8 to -6AN for the 05 rail
    yeah, very common fitting that even SDPARTS.COM carries.
