what should i get done to my transmission because its about to go ?
simplest answer is to convert to 80e but if you want to keep the 60e get it rebuilt with quality OEM parts and clutches. I prefer the borg-warner clutchs and kolene steels. I would suggest going to a corvette servo setup while its down. You might consider getting a Circle-D modded Trailblazer stall converter to replace the factory unit. A Beast sunshell should always be installed if you don't have one in there already.
Thanks for the information And what about a shift kit to sorry I'm new at this I'm 17 and I'm trying to learn much as a can about everything about my truck I wanna get alot of stuff done to it and would this stuff you told me would it miss my rear end go out ?
Depends on your rearend, how you drive it, how old/mileage and what kinda power your putting down. A lot of guys get away with those mods no problem others Grenade their rearends in stock form.
Gears and a locker would be a great upgrade and if you loose your rearend its a great excuse![]()
I don't think I'd put a shift kit in it. The tune can handle any shift changes needed.
