Dextron III flush, then add Dex VI?
I just purchased a 2003 4l80e for my 2007 nnbs 1500 ccsb. I picked up a transgo hd2 for it and I was going to install the kit before i installed the trans but when I removed the pan the fluid was black. Before I invest more into the trans (installing the transgo) I would like to try to run some fluid through the trans to cycle the black fluid out as well as make sure the trans still works. Can I use Dex III to cycle the black oil out and then put in Dex VI? I'm thinking Dex III is probably the fluid that was in there anyway. The trans has been out of a vehicle for over 2 years and it only has 60k miles so I doubt it was ever even changed even though the mechanic I bought it from said he just changed it. If he did change the fluid and he used Dex 6 can i still cycle the trans with Dex 3 for 500 or so miles then drain it and put Dex 6 back in the trans? His excuse for the black fluid was that he changed the trans fluid but then reinstalled the verter which had black fluid...does that sound fishy? Anyway I was trying to save 30 bucks
Thanks alot!
2007 GMT900 CCSB 5.3 VTS2300 Twin Screw Supercharger, Doug Thorley LT's, True 3" Duals into Dynomax Race Bullets, Nelson Tune, 4L80e w/transgo HD2-D, Truetrac, 4.10 r&p
Need list: Stall, PLX 200 for my crappy AFR, X-pipe, GM 20's.
