Results 1 to 8 of 8
Thread: Speed @ 3,900rpm in OD ?
    Mar 2005
    Eagle Pass
    Thumbs down
    I was wondering if anyone could tell me How Fast I am Running @ 3,900 rpm in overdrive with stock gears and Stock Height tires on a 2000 Silverado extended cab with a 5.3 ? I will hopefully find Out Soon When I take My truck To Allen, But Till Then, I am Curious...., if the Numbers Dont seem right then its probably time For Junkyard Trans # 3!
    Jun 2003
    North Central Arkansas, Cave City
    Transmission Ratios:
    1st: 3.06 2nd: 1.63 3rd: 1 4th: 0.7
    Tire Diameter 1: 30 inches
    Rear Gear Ratio 1: 3.42:1
    MPH
    RPM 1st 2nd 3rd 4th
    1000 8 15 25 36
    1500 12 23 38 54
    2000 16 31 50 72
    2500 20 38 63 89
    3000 25 46 75 107
    3500 29 54 88 125
    4000 33 61 100 143
    http://img.photobucket.com/albums/v6...nstruckls1.jpg
    05 Joe Gibbs RCSB 5 gear
    99 Vette / 6 gear
    02 Honda Goldwing
    00 Hayabusa
    Mar 2005
    Eagle Pass
    Thanks For the Info, That Sounds about right... I am guessin 130ish, W00t!
    Really hard to tell since some of it depends on how much your tires balloon out at high speeds. You're pushing a dangerous limit on stock tires at 130 mph. We still like you and would like to keep you here a while longer so please, get some speed rated tires for running that fast. Stock tires aren't rated for over 90 mph. I see you said stock height. Hopefully you have some tires safe for those speeds.
    Dec 2003
    What he said, I think that's why i blew one out last weekend doing 80. It was a good thing it was in the rear. Oh yea try 4600 in OD.
    2000 Chevy Silverado 2500 ECLB w/6.0 , 4L80E auto, 4.10 G80, K&N, Nelson Dyno Tune, 02 PCM STS TURBO , 44# injectors, IC ,HPTuner and 160* thermo 348 rwhp, 394 rwtq @ 5 psi
    60'=2.241
    1/8=9.352@77.39
    1/4=14.40@ 96.67
    Jun 2004
    george west texas
    thats why i bought my 305/50/20 goodyear gt2's...i can go alot quicker and not worry bout it
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Jan 2005
    Conway, AR
    What would 285/75/16 be rated at?
    Chris
    Mar 2005
    Eagle Pass
    Thanks For The Concern, The Thought of a Rear Blowout With My Stepside Bed Mortifies me!!!,I do Have A Nice Wheel Tire Combo 275/60HR17's, But one Of the Rims is Bent and Discontinued, SOOO @ The Moment I am Running Ell Cheapo 255/70 LT16 Remington Wide Brute A/W 111 speed rating(they Were Free) On Cheap Factory Sized aftermaket Alloys.. I run sustained(hour-2hr+) Triple Digits every weekend Going From FT Sill Ok to Mexico And/or a Border Town Fairly Close To S.A.(585.37miles in 8-6.45 hrs Depending on Austin traffic&#33.. Event Free So Far, And yes They Baloon out, The Center is wearing Out kindof Rapidly.. Was Thinking Of Going With Bridgestone Dueler H/P 265/70HR16's,Can Someone Suggest A Better Tire This size or 255/70???, Also, Is There An aftermarket Speedo That Will Accurately Display My Speed?, Or am I limited to the Denali or Escalade Cluster?
