Ok so I've got a 99 2500 4x4 ec lb. Its got 373 gears the 4l80e trans and 285 70 16 tires. In the last two weeks I installed ls2 heads, comp 222 224 112 cam, 2800 stall, long tubes, 8.1 injectors and a cold air intake. Its still pretty much the stock tune accept with the 8.1 injector values. Ill tune it on the dyno this weekend. The problem is that I can see that the truck is still going be kind of a mutt off the line because first gear is too effin high in this tranny! I mean at like 5200rpm in first gear in showing about 60 on the speedo and I'm going even faster than that because speedo is not calibrated for the 285s!#! Not to mention that after the tune and with this cam my shift points will be more like 6200 or more. Ill be shifting out of first gear at like 70mph!!! What a joke.... if I run any smaller tire the truck looks stupid cause its so long. I mean it seems like I would need 544 gears to shift into second around 35 or so witch is what I want it to do. Do they even make gears that high for the front diffs of these trucks? What would I be tacking in od at 70? Could I get a gear vendors overdrive and somehow use it to cut first gear in half? What do you folks do about this atrocious first gear ratio? I think a 60e has like a 3.08 ratios where the 80e has a 2.40 or so. Crazy!
