Results 1 to 10 of 26
Thread: 2004 2WD 4L60E For Sale
    As title says for sale, at the point where you can decide a few things. Will build stock and sell for $400 local. I'm willing to meet half way or set up a time to pick up, no shipping. This one was not hurt badly at all (check ball peened through spacer plate and no 2nd apply, band hurt, no biggie). I will build with your aftermarket hot rod parts if you supply them for the same price as long as they install generally as stock. Heavy mods will require some more $$$ but I work cheap. Need to get this out of the way. Price includes GM stock parts, mount, stock converter (flushed), bell housing. I took it all the way down to the low/reverse clutches (all the way gutted) and cleaned it on the inside, checked the low roller clutch and low/reverse clutch piston (no issues found), pulled the servo pistons and cleaned/resealed (no issues found), pulled valve body and inspected (no issues other than previously mentioned over-peened check ball). Input housing and rear pump cover OK, no issues with teflon rings or pump cover bushings, input sprag OK, sunshell OK, no burnt clutches although I will replace with stock. Even 3-4 looked good. Both accumulators OK, no issues. Came out of 2004 1500 Silverdao with about 55K miles, 5.3 engine. It won't look like this when you pick it up, showing honest picture of item as it sits today...still partially disassembled in case you want to supply me with other internals. Send me a PM if interested.
    No takers? Someone needs this as much as I need the cash.
    You might check PT. I think I saw a guy looking for one on there.
    Still have it.
    Fort Worth, Texas
    Is shipping a possibility?
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
    Oh no, why Steve? Tahoe trouble? Not sure how I'd ship it.
    Fort Worth, Texas
    No, everything is good. I mistakenly read 4WD not 2WD.... With 106K on the clock of my 2001 and the way it shifts every now and again I'm on the look out for a good replacement for it, looking to put one in this Spring.
    Bump for a good guy....
    2004 Tahoe LT
    1971 Chevy C10
    It's all assembled with Borg Warner clutches and band, a new GM separator plate, all the needed seals, etc. I'll post a picture in the morning for anyone new.
    Broken Bow, OK
    Seems like I should know this, but where in North Texas?
    Crossett,Ar
    Still have it GG? Got a buddy that has been asking me to find one. I dont kno if he will come off the money but if you stilll got it ill try to make a sale for you.
