Originally Posted by
molitor
if you have the original dropin in unit, you can replace the pump with the walbro, just remove the old pump from the unit, install the walbro in its place, solder the connections and shrink wrap them and install new fuel line from the pickup to the pump and from the pump to the top of the assembly. then you will have the 255lph pump installed just like the factory unit, it would also be a good time to test the sending unit and inspect it closely if you are re-using the original
you can buy a replacement unit on ebay for probably 80 dollars and just replace the pump that comes in it
