Results 1 to 6 of 6
Thread: Do i need lifters
    Mar 2010
    houston,texas
    Do i need lifters
    im doing a cam swap on my 6.0 engine im putting comp 918 springs and new push rods but wasnt sure if i should replace lfter the engine has 47k on it and what about the timing chain and gear
    2006 silverado crew cab z71 6.0
    Nelson Tuned
    LT
    285/75/17 bfg mud terrain km/2
    TSP 220
    So Cal
    camp swap?
    2002 Chevy Silverado LT 5.3L z71 ECSB, Fully Built DMC 4L65e, Transgo 4L65E .500 Boost Valve, Transgo Shift Kit, Billet 1st Gear Servo, 2nd Gear Sonax Super Hold Servo, 4th Gear Billet Servo, Rebuilt 10 Bolt w/ OEM G80 and 3:73's, Dumped Single 3" Spintech Muffler, 3" E-Cut Out
    Mar 2010
    houston,texas
    ha cam swap let me edit that
    Nelson Tuned
    LT
    TSP 220
    newburgh, NY
    Timing chain yes just good insurance. Alot of people don't change lift and they are fine. If it was my motor change a cam change lifters because they have a wear pattern to a specific lobe and when add a new lobe in the equation there will be more wear. I was always taught you can do lifters and same cam but new cam new lifters.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
    thats old school thinking for guys running lifters that did not have a roller bearing on them, flat tappets. Only replace the lifters if they're noisy or you notice wear on the camshaft that is not normal, when running a roller camshaft.
    newburgh, NY
    It may be old school thinking and not needed for roller lifters but thats the way I roll.
    Step 1. crus at it.
    Step 3. torch it.
