Results 1 to 9 of 9
Thread: Hidden Hitch ?'s
    Augusta, Ks
    Hidden Hitch ?'s
    Whos running a hidden hitch with their roll pan? Whered you get it from? How much? And how hard was it to install?
    2004 Buell XB12s
    GA
    CLASS III ROLL PAN RECEIVERS - JCWhitney
    cheapest i saw. Should bolt right up same as stock.
    04 5.3
    224/224 .566 .566 114
    3200 Circle D
    LT's
    60e
    Nelson Tuned
    p1sc in closet
    casey23 Guest
    My white truck has a hidden hitch behind the roll pan so i can pull my jetski...... just have to be carefull not to put the turbo in the lake when i back up.... and 3000+ stall is NO good on the boat ramps...
    Jun 2004
    george west texas
    Quote Originally Posted by casey23 View Post
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Broken Bow, OK
    There used to be a seller on ebay that had them new. That was the cheapest I had found. I was gonna put one on my truck, but then decided not to. I have a 3500 for towing, I probably never would have used it anyway. I have a tag flip bracket for use with one I don't need if you need one.
    Dec 2009
    I had my 1968 shortwide for about a year before I noticed it had a hidden hitch behind the plate.
    Wichita Falls, TX
    I've got the hitch and tag bracket I will sell. Both are simple installs. Pulled the ska-doo to the lake in this truck once, never happening again.
    Augusta, Ks
    PM's sent
    2004 Buell XB12s
    Oct 2009
    Reidsville, Georgia
    I also have a class 3 hidden hitch and flip down bracket that I'd sell pretty cheap, its used but no harm, all hardware and even some wiring
    2000 2-toned silverado, Totalled. Gone But not Forgotten.
    Now: 2002 black rcsb chevy. 5.3, P&P 862's, Comp 224/230 .58*/.59* 114 LSA, Racetronics 44lbers, ARP 2000's, Ebay long tubes, 4L80E, 3800 yank pro, transgo HD-2, 4.10's, True-Trac, Walbro 255, Nitrous Outlet plate setup for 200, 80mm BBK, 3" Magnaflow, and Raggedy traction bars! Waiting to be istalled, F.A.S.T LSx intake..........
    Best: 7.40@90 1/8th
    Tuned by: DIXIE PERFORMANCE
