Results 1 to 8 of 8
Thread: 1999 to 2002 4L60E from a Full size TRUCK (5.3L)
    Jun 2003
    I need a cheep 4L60E tranny from an LS 5.7L truck.
    I want to rebuild it myself...........so If you have one kicking around let me know.
    Thanks
    San Antonio, TX
    try to find someone on the net who is thinking about going with an upgraded trans and see if you can buy his core.
    just a thought.
    here's one from ebay
    here's another one
    one more
    good luck,
    allen
    San Marcos Texas
    TBYRNE has a couple of trannies for sale used. I was thinking about getting one.
    Oct 2004
    i have one out of an 02 475.00 this is a good trans not a core.
    austin
    800-447-0611
    Austin Jenkins
    Hi-Way Auto Parts
    Brownwood Tx, 76801
    800-447-0611
    Hmmmm..... 5.7L LS in a late model truck? Cool.
    Oct 2004
    .......... 550.00 for a good trans out of 98 1500. with 48K
    Greg he has the listing as a 1999-2002 trans is what he is hunting then he types one for a 5.7. guess i will just cover both ways
    Austin Jenkins
    Hi-Way Auto Parts
    Brownwood Tx, 76801
    800-447-0611
    98 C1500 has a different transmission than the 99 doesn't it? the bolt pattern, torque converter, bell housing, input drum and pump stator are different on the 5.7L trucks than the 4.8, 5.3 and 6.0L engines, correct? I know you cannot put a 98 4L60E in an LS1 without custom parts to make it work. Isn't the bolt pattern on the 4.8, 5.3 and 6.0L engines the same as the LS1/LS6 block? I know they are basically the same engine only in cast iron instead of aluminum.
    Dec 2004
    Andrews, NC
    I have a 4l60e out of my 2002 gmc sierra. It needs to be rebuilt because it started slipping but it has a transgo shift kit and corvette servo in it. If you want it you can have it with the torque convertor for $300
    2002 GMC Seirra scsb, 5.7LS1, Twin 62-1 turbos, Compcam 222/218, 4l80e, and Hptuners
    2006 GTO Black/Red, 6.0 M6, 238/240 cam, SW LT, exhaust & bolt ons = 438rwhp411rwtq!
