Results 1 to 7 of 7
Thread: Got a problem
    Oct 2003
    stuttgart,ar
    Red face
    missing when I start to get into boost.Sounds fine running around town,
    just when the needle hits 0# on the gauge it starts to miss. What
    could couse this? sparkplugs,wires or something else.
    2000 SWBRC 5.3,radix,e-fans,no cats,true duels
    2 21/2in delta force race muffs,4.10 with eaton
    e-locker.Descreened MAF & throttlebody bypass.
    FLP level 5 4L65E,PI 3000 stall,Dynatech headers
    Nelson tune
    2005 GMC 2500HD 4door 4x4
    1989 Chevy Suburban 4x4 ( Sir Leaks-a-Lot )
    probably need to shut the gap on the plugs abit. The wind coming through may be acting like someone blowing out the candles.
    Oct 2003
    stuttgart,ar
    Got some new plugs today,what should I gap them to?
    Hope this helps,if not I'll do something else.
    Nelson tune
    Probably down to .035" for a good spark under boost.
    Oct 2003
    stuttgart,ar
    Well I changed the plugs and she runs 100% better now!
    There was one plug that was cracked,must have
    hit it during the header install.
    Nelson tune
    Did you use the factory gap spec or did you gap them down?
    Sep 2004
    Thats good its always nice to hit it on the first shot
    http://i15.photobucket.com/albums/a3...lla/breeze.jpg 03 Silverado LS, 6.0 RcLb
    Go: Radix 2.9, 100mm Idlers, GT2-3 Cam & Springs, Long tubes, 2.5'' duals, Cut outs, E Fans,
    Built 4l65e, 2600 Conv, 3.90 Gears, Eaton Lsd, Caltracs, Tuned by F-Body Central
    Show: Eagle boss 309, Toyo's 285/50s, SS Bumper cover & Spoiler, Roll pan, 2'' rear drop.
    Track times 12.304 @ 110.30 with a 1.747 60'
