Results 1 to 8 of 8
Thread: pcm vat link
    Jun 2009
    Houston,TX
    Cool pcm vat link
    hey guys i bought a used pcm believing it was from a V8 TRUCK, 2001 operation system, i know i have to link it to my truck, but when i click on relink tap, it says its from a V6 truck can i still make it work on my truck as long as i change it to a v8 after i relink it. or should i get a v8 pcm. let me know thanks.
    2000 gmc, 5.3, 220/224 comp cam,918 springs&harden push rods,long tubes,polish throttle body, 39lbs injectors,msd inline fuel pump,msd spark plug wires, 150shot, 3500 tci,servo,3.90w/eaton posi,m&h drag tires, tune by flaco,still need to re tune for fuel upgrade.
    you need to take the PCM to someone that can put the factory tune in it for the engine/vehicle you're going to run it in or a suitable vehicle for the application you're using.
    Feb 2009
    Houston
    take it to TranStar off of 45 and sheperd.....
    they can load a stock tune on it
    A lot of CarQuests can do the load for you, too.
    Jun 2009
    Houston,TX
    Smile flashing pcm
    Well I talked to the guy I got the pcm from,I told him the problem and he said to take it back exchange for another, am going today after work. Any suggestions before I go change it out for a V8 pcm.
    Nope. I've always run the 411 pcms, faster processors and more agressive base tunes, plus I believe you can control electric fans with them vs the earlier PCMs.
    Jun 2009
    Houston,TX
    Smile pcm installation
    So I installed the new/pcm the junk yard was able to match the serial #. I went ahead and relinked it and started the truck, it did start but miss firing of course cause of the cam and stuff,my question is can I copy and paste from the other tune. Or should I input the value my self.
