Results 1 to 9 of 9
Thread: Did I miss it?.....5.3 to 6.0 Swap
    Mar 2010
    Guthrie, OK
    I just joined this group and I looked through the posts and couldn't seem to find what I was looking for. I am new to GenIII engines and want to know how difficult and what is involved in swapping a 6.0 in place of a 5.3 in a 2002 Suburban?
    Tyler, TX
    there is a post on the genIII 4.8l to 6.0L swap, thats one you are looking for
    www.tjc.edu
    Broken Bow, OK
    Nothing really. Just pull your long block and replace it with the 6.0. Then tune the PCM.
    Augusta, Ks
    Depends on the year 6.0 if its 2001 up then no problem. just change ur flywheel, tune and go. however if its a 99-00 then it wont be easy
    2004 Buell XB12s
    Mar 2010
    Guthrie, OK
    Thanks Guys. Which of the Externals and accesories can I use off of the 5.3?
    Everything.
    It's like going from 305 to 350
    Mar 2010
    Guthrie, OK
    So, if I just get a Long Block I should put bigger injectors in, correct?
    Broken Bow, OK
    No, They are the same size.
