Hello all,
I am picking back up a project truck I was working on a few years back and am running into some problems with my 4l80E not shifting.
The setup:
-Vortec 5.7L
-aftermarket wiring harness from injection technologies
-PCM flashed by Centech for the 5.7L/4l80E (supposedly...)
-4l80E
The problem:
The tranny will not shift and acts the same regardless of whether or not the main tranny plug is connected or not. It has reverse and what feels like 2nd gear. Could be 1st. I think I've checked the wiring for anything stupid, all the pins in the main harness match up and look like their connecting, both speed sensors have been swapped and are plugged in, I tested the TCC PWM solenoid and the B Solenoid and both appear to work (on the bench). I've also tested resistance on the PWM solenoid pins on the main tranny plug and it appeared to be fine.
It throws codes of P1860 and P1864.
I'd like to be able to rule out a computer issue and focus on the tranny/wiring or know that I need to get the PCM reflashed (or maybe I have a bad one-- but the engine runs pretty good??).
Anybody have any pointers?
Thanks for any help.
