Results 1 to 10 of 15
Thread: Thinking about custom grind 222/224?
    Southern WI
    So I'm going to use tax returns this year for a new cam and springs. I've been really set on the tsp220R..but I was curious how a 222/224 .581/.581 112 LSA with 110 ICL with the XER lobes would be in this pig. I got the circle-d 278mm converter already in the truck...so I need a cam that'll work good with that. Just give me your opinions, thanks guys.
    Mike
    2000 RCSB
    '05 LS2 11.5:1 C.R. l K&N l LT's l Torquer V2 l PAC Springs l Manley 7.4's l 92mm TB l LS7 Lifters l Circle-D 3200 l P&P TB l ARP Rod Bolts l LS1 E-fans l Nelson 93 Tune l Brand-X 100 Shot l Walbro 255 l Duals w/ X and Magnapacks l Vette Servo l Transgo S.K. l 30K Cooler l Detroit Tru-Trac l Motive 4.30's l ARP Cap Studs l TA Girdle
    Hmmmm....yeah, that will work pretty well. A little more duration and the same lift. If there is a big price difference, then I wouldn't worry about the custom grind--it isn't worth the extra $$$ cause you honestly won't be able to notice the difference in power, if there is any. If you are gunna go with a custom grind--why not make it worth the time and money?
    As a reference (and with your truck and it's mods) I would go with a high 22X duration and keep the lift in the .58X range.
    Maybe something like a 226/230 .585/.588 112 LSA (109 ICL).
    Southern WI
    That cam would probably be crazy! if I had a slightly bigger stall I'd try it, I'm probably sounding like a little girl haha...I don't want to lose all my low end is the only thing. Thanks though tyler I think you just picked my cam for down the road when I build a 6.0!
    Mike
    2000 RCSB
    Quote Originally Posted by 1_fastsilverado View Post
    PROBABLY be crazy??? It would work well for you! I installed a cam very close to that in Garrisson's truck (224/230 .581/.588 112 LSA) and he was running a 3000 stall at the time and it ran excellent. He laid down 345 RWHP (~420 hp at the motor) on a mail order tune and clocked a 13.7 1/4 mile time I think. He didn't have any issues down low. And he had the same mods as you. So.... Quit being a Nancy! Go big or GO HOME!
    S.A. Texas
    if you are gonna do a custom grind cam let someone that picks out cam for a living do it for you. Pat G on ls1tech does it for 25.00.
    Nov 2009
    chicago, il
    Quote Originally Posted by SLO TRUCK View Post
    I'll pick cams for a living too if i get payed $25 to do it!
    GET OUT OF HERE WITH THAT RICER MATH!
    If you aren't living on the edge, you're taking up too much space.
    Wichita KS
    you looking for a cam?
    2006 Trailblazer SS RWD
    Keith--you are such a funny little girl...
    Wichita KS
    but seriously...i have cam for sale!
    Southern WI
    Haha fine tyler you talked me into it...now it's just a matter of $$$.
    Keith what cam are you selling?
    Mike
    2000 RCSB
