Results 1 to 10 of 28
Thread: wheres the oil pressure?
    Feb 2010
    Odessa, texas
    just rebuilt a lq4 and it wont make more that 20 pounds at idle and when it warms up its about 7 pounds ive changed the seal and the oil pump and nothing
    any advice?
    Replace the cam thrust plate if the seal is damaged or warped. Another thing I've started doing is putting a bead of silicone around the pickup tube between the oring and the swedged metal bead. Be sure to let the silicone set up for at least two hours before starting the engine so the silicone has time to harden a little.
    Pittsburgh, PA
    thats a loaded question. can be so many variables. wrong cam bearings, wrong main bearings, bad O ring, pump not sealing to block, oil passages clogged
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    Dont forget the "forgot to install the dogbone" into the oil galley at the back of the engine.
    Feb 2010
    Odessa, texas
    i used gasket sealer on the oring and the cam bearing and rod bearings are brand. new cam bearings are from the dealership. the thrust plate stayed in a box the entire time the motor was apart.never plled the dogbone out of the motor. when i changed the seal the second time(with the motor in the truck) i had to clean a lot of gunk out of the pickup tube. im think maybe the oil prssure sending unit might be clogged so im about to pull it out and check it
    Pittsburgh, PA
    Quote Originally Posted by danger_ranger83 View Post
    new bearings dont mean anything if they arent properly matched to the crank. a polished or cut crank needs over sized bearings. if you didnt have this done to crank are you sure the crank didnt need checked?
    the sensor is reading so i woudl rule the sensor out
    412 Motorsports
    Feb 2010
    Odessa, texas
    the rod bearings only got changed bc the motor blew a head gasket and the bearings didnt look good
    so there is NO way the sending unit could be the problem?
    Even with a new o ring on the pick up, you can still put it in wrong and pinch the o ring. Do what i did and cut a little section out of the two pick up tube brackets so you can move it around and get the oring to sit right.
    Pittsburgh, PA
    what color O ring are you using?
    412 Motorsports
    Feb 2010
    Odessa, texas
    wheni put the pickup tube on i put it in the oil pump and tightened it down before i put it on the motor
    im using the black seal that came with the oil pump which is the same as the blue one from dealership
