Results 1 to 10 of 15
Thread: How many are running true duals?
    Jun 2009
    Youngsville, LA
    How many guys are running true duals on their LS engine? I had always heard that these engines lose HP from true duals. Is that true? The reason I ask is I have a Tahoe and when I perform my swap, I'll have to redo the exhaust.
    Well because I have a 2dr I can run a single pipe down each side behind the long tubes. I will be using high flow cats and magnaflows.
    Will it rob horsepower? Would it be better to do a y-pipe, or just do the above and connect an H or X pipe? Or just run without an H/X pipe
    The engine will have a mild cam and mild headwork, with the normal bolt ons.
    2011 Chevy crew cab 5.3
    2013 Chevy crew cab 5.3
    Wichita Falls, TX
    I have a dual in/out magnaflow with a built in x on mine, I saw the same times at the track as I did with the single flowmaster. I'm slower than molasses anyway though.
    i run 3" without any type of X or cross ( muffler ) true duals, but with your hp i would go no bigger than 2.5 in pipe size but it would be cheaper if you can use pass. and driver side, plus its less bending or less bends
    Simple: 408 on steroids!
    single digits coming soon!
    Oct 2007
    Bandera, TX
    i love my duals... added tons of power....
    i have dual 3 inch magnaflows
    Round Rock, TX
    I have dual stages also tons of power too!!1
    Quote Originally Posted by skeet View Post
    ...i would go no bigger than 2.5 in pipe...
    Exactly. If you want true duals, only go as big as 2.5" and run an x-pipe. If no duals, merge the exhaust into a 3" y-pipe and run a single 3" pipe back...
    Jun 2009
    Youngsville, LA
    duals it is then, I can just run them straight back from the headers. a single 2.5" on each side.
    That will make the exhaust installation a whole lot easier
    thanks
    Quote Originally Posted by texasbred View Post
    thanks
    I'd add the x pipe.
    Quote Originally Posted by DBRODS View Post
    yea me too, it adds alot of power
