I have a brand new Explorer PRO COMP ES2000 steering stabilizer PN 219200 I will sell for $32.00. I will even throw in a new, unused boot with it. Shipping is free, in the spirit of the holidays. This part number is used on many vehicles. The receipt says it fits '84-01 TJ/XJ/ZJ Jeep, '92-98 4WD Blazer, 92-94 2WD Blazer, 88-98 K1500 pickup, 92-99 K1500 Suburban, 88-98 K2500 Suburban, 88-98 K2500 pickup, 88-98 K3500 pickup, 83-94 S10 Blazer 4WD, 83-98 S10 Pickup, 95-98 Tahoe 2&4WD, ..... Many Many more applications. If you don't have a stabilizer already on your vehicle you will have to buy an installation/mounting kit. The shock is 12-1/4" compressed and 19-3/8" expanded with eyelets on both ends.
CHEVROLET BLAZER 1992 - 1994 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET BLAZER 1992 - 1994 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET BLAZER 1995 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET BLAZER 1995 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET LUV 1979 - 1983 ALL SINGLE, SHOCK CYLINDER ONLY, BOLTS TO STOCK MOUNTS
CHEVROLET PICK UP FULL SIZE 1988 - 1998 3/4 TON LIFTED SUSPENSION, WITH PRO COMP 6" LIFT
CHEVROLET PICK UP FULL SIZE 1988 - 1998 3/4 TON WITHOUT LIFTED SUSPENSION, SINGLE, WITH STOCK MOUNTS, SHOCK CYLINDER ONLY
CHEVROLET PICK UP FULL SIZE 1988 - 1998 3/4 TON WITHOUT LIFTED SUSPENSION, SINGLE, WITHOUT STOCK MOUNTS, SHOCK CYLINDER ONLY
CHEVROLET PICK UP FULL SIZE 1988 - 1998 1/2 TON LIFTED SUSPENSION, WITH PRO COMP 6" LIFT, SHOCK CYLINDER ONLY, SINGLE
CHEVROLET PICK UP FULL SIZE 1988 - 1998 1/2 TON WITHOUT LIFTED SUSPENSION, WITH STOCK MOUNTS, SINGLE, SHOCK CYLINDER ONLY
CHEVROLET PICK UP FULL SIZE 1988 - 1998 1/2 TON WITHOUT LIFTED SUSPENSION, WITHOUT STOCK MOUNTS, SINGLE, SHOCK CYLINDER ONLY
CHEVROLET PICK UP FULL SIZE 1988 - 1998 1 TON WITHOUT LIFTED SUSPENSION, SINGLE, WITH STOCK MOUNTS, SHOCK CYLINDER ONLY
CHEVROLET PICK UP FULL SIZE 1988 - 1998 1 TON WITHOUT LIFTED SUSPENSION, SINGLE, WITHOUT STOCK MOUNTS, SHOCK CYLINDER ONLY
CHEVROLET S10 BLAZER 1983 - 1994 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET S10 BLAZER 1983 - 1994 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET S10 PICK UP 1982 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET S10 PICK UP 1982 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
CHEVROLET SUBURBAN 1992 - 1999 4 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY, WITHOUT LIFTED SUSPENSION, BOLTS TO STOCK MOUNTS
CHEVROLET SUBURBAN 1992 - 1999 4 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY, WITH PRO COMP 6" LIFT, 6 LUG WHEELS
CHEVROLET TAHOE 1995 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, 4 WHEEL DRIVE
GMC JIMMY 1995 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
GMC JIMMY 1995 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
GMC S15 JIMMY 1983 - 1991 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
GMC S15 JIMMY 1983 - 1994 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
GMC S15 PICK UP 1982 - 1991 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
GMC S15 PICK UP 1982 - 1991 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
GMC SONOMA 1991 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITH STOCK MOUNTS, 4 WHEEL DRIVE
GMC SONOMA 1991 - 1998 ALL SINGLE, SHOCK CYLINDER ONLY, WITHOUT STOCK MOUNTS, 4 WHEEL DRIVE
GMC SUBURBAN 1992 - 1999 4 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY, WITHOUT LIFTED SUSPENSION, BOLTS TO STOCK MOUNTS
GMC SUBURBAN 1992 - 1999 4 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY, WITH PRO COMP 6" LIFT, 6 LUG WHEELS
ISUZU AMIGO 1989 - 1995 2 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY
ISUZU PICK UP 1982 - 1983 4 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY
ISUZU PICK UP 1989 - 1991 2 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY
ISUZU RODEO 1991 - 1995 2 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY
JEEP CHEROKEE MID SIZE 1984 - 1994 ALL SINGLE, SHOCK CYLINDER ONLY, BOLTS TO STOCK MOUNTS
JEEP COMMANCHE 1986 - 1992 ALL SINGLE, SHOCK CYLINDER ONLY, BOLTS TO STOCK MOUNTS
JEEP GRAND CHEROKEE 1994 ALL SINGLE, SHOCK CYLINDER ONLY, BOLTS TO STOCK MOUNTS
JEEP WAGONEER MID SIZE 1984 - 1990 ALL SINGLE, SHOCK CYLINDER ONLY, BOLTS TO STOCK MOUNTS
JEEP WRANGLER 1987 - 1996 4 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY, BOLTS TO STOCK MOUNTS, EXCEPT CSC EQUIPPED
JEEP WRANGLER 1997 - 2005 4 WHEEL DRIVE SINGLE, SHOCK CYLINDER ONLY, BOLTS TO STOCK MOUNTS
NISSAN PATROL 1980 - 1988 ALL SINGLE, SHOCK CYLINDER ONLY
NISSAN PATROL R 1984 - 1988 ALL SINGLE, SHOCK CYLINDER ONLY
NISSAN PATROL R 1989 - 1994 ALL SINGLE, SHOCK CYLINDER ONLY
