Results 1 to 10 of 10
Thread: nelson tune
    Sep 2004
    Breaux Bridge, LA
    sup yall!
    i'm looking forward to getting the nelson tune after my mods are done when i get back home from the middle east. can my pcm be tuned for two different tire sizes? i plan on getting some 255/70/16's for the street and some street et's 26/10.5 or 26/11.5 for the strip. if the tune can only tune for one tire size, can the hypertech still be used for the other tire size?
    holla back at me
    thanks,
    lance
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
    San Marcos Texas
    You will love your Nelson's tune! THE PCM will only tune for one size at a time. The hypertech will work great for the tire size change on the fly. I use a different size slick at the track and don't worry about changing the PCM for that.
    Sep 2004
    Breaux Bridge, LA
    ok, let me get this strait, the nelson tune will tune my shift points for my street tires and i can use my hypertech for my slicks? i want it tuned to where i just have to leave it in drive on the street and strip.
    holla back,
    lance
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    Knothead Racing
    Do all of us a favor and don't worry about how fast you are going on the strip. That is what the time clock is for. The 1/10 of a second it takes you to glance down to see how fast you are going could be the difference between life and death when racing.
    I would only worry about the speed accuracy when on the highway. You won't get a speeding ticket at the track.
    San Marcos Texas
    Originally posted by bluecajun5.3@Dec 12 2004, 11:37 AM
    ok, let me get this strait, the nelson tune will tune my shift points for my street tires and i can use my for my slicks? i want it tuned to where i just have to leave it in drive on the street and strip.
    holla back,
    lance
    It should work fine with both sets of tires without the correction for the speedo. I would think the shift points would only need to be corrected if you had a gearing change not with a tire change. You can try it with your hypertech and see if there is any change at the strip.
    Jeff
    The pcm does not know if you change tires or gears. It will shift when it was programmed to shift, by rpm and speed parameters set by LS1Edit. The engine will operate just fine with the different tire size for racing. You could have Allen program your PCM and then buy yourself a cheapo handheld to change your minor alterations later for track tires.
    Sep 2004
    Breaux Bridge, LA
    i think i got yall.
    once allen tunes the rpm shift points for my motor, the engin will shift at that rpm with both sets of tire sizes, right?
    lance
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    Knothead Racing
    Jun 2003
    just put them on and go for it. like sayed before the hyper will not help much. sell it.
    04 supercrew 5.4 3 valve-magnaflow catback
    formerly 02denali 12.79@107
    Nov 2004
    i think a big thing that blue cajun is worried about is not only shift points with different tires but by using a shorter slick the truck shutting off on the top end unless nelson tune moves that speed limiter way up. i dont know how high can allen move that up whats the max mph
    be easy seth shootin off shicks like its stupid
    01 pewter extendocab 4.3 bout to have 6.0.
    18'' boss motorsports dubs
    2/4 drop, toneau cover
    alpine cd player, directed tweeters, 1200watt ma audio amp,
    3 jl audio 12's in custom ported box its all show.
    wife has a 99 honda accord with a open filter makes a weird noise sounds like doof.doof.doooof. lol
    yall be easy seth
    Jan 2005
    Conway, AR
    I was told by Allen that he usually sets the limiter to 135....I have no need to hit that so its fine by me!
