Results 1 to 10 of 22
Thread: Help me Punk this Kid
    Mar 2007
    Newark, Delaware
    This kid I used to be friends with traded his Powerstroke for a 98 Camaro a couple months ago. This kid is known for always making up all kinds of BS to sell his vehicles. Once you read his Craiglist ad, it's obvious he knows nothing about his car.
    1998 z28 camaro 468 rwhp - $15000 (wilmington)
    2006 cast iron block ( new ) 6.2 liter, 5.7 forged crank, longer rods stoking to a 402, 556 lift roller cam/226 dur, L92 alum heads w//205int, 185exhaust valves, 11.1.1 comp all forged internals, carlin sharp roller rockers, LS7 injectors and wirering harness, areomotive 255 intank pump, all braided line all the way to tank, motor has a main girdle and 7 quart pan with sump, NGK plugs , and alwaye use 93 oct or more due to the high comp., long tube slp headers and 3" y pipe with cats, SLP loudmoth 2 cat back. has centerforce duel friction clutch. if you do 4:10 gears and alittle susp with drag radials and fix the trans it will be a low 11s car car is alittle detuned for steet and is making about 415whp on agessive tune made 468 whp but that was still on pump gas . give me a call a if you have any questions
    the trans needs a third gear syncro cost about 500$ to have it fixed email me for pics
    kyle-302 353-8488
    I know most of you guys will notice a bunch of things wrong with the ad. He's actually pretty funny, so call or text him and and you'll get a kick out of the BS he'll feed you.
    spring, texas
    He seems to be low on power with what it has in it. I am making 421awhp on 24's. L92's AND LS3's are head and shoulders above the LS1, 2 and 6's.
    Not sure what is wrong with his add, other than the tranny is broke and he wants 15G's for a 12 year old wooden wagon....
    2009 YUKON DENALI,BLACK ON BLACK, LS3, Dynomax 4" cat-back, VARA-RAM INTAKE, KOOKS LT's, MSD IGNITION, LS VVT hot cam, ZO6 springs, HP tuned to 421awhp, 12.54 at 108mph on 24's.TUNING FROM THE DARKSIDE.
    06 KAWI BRUTE FORCE 916cc 6.80's in the 1/8th. ALL MOTOR. New found drug addiction is getting "HER" into the 5's. "EVER HAD A QUAD TAKE YOUR MONEY?"
    Pittsburgh, PA
    his parts list makes no sense. half the shit isnt correct
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
    stroking my motor with rods should be alot cheaper than a stroker crank...
    Psalms 144:1
    Si vis pacem, para bellum
    Evant,tx
    well lets see did they make a 6.2 in 06. i thought it was in the nnbs when the 6.2 showed up. a stock 5.7 crank with longer rods to stroke it? hello im no rocket scientist but damn this dude is dumb. the list goes on but you get the picture
    S.A. Texas
    I emailed him for pics and asked some questions, haha i will post up what he emails me back
    Wichita Falls, TX
    I've never heard of Carlin Sharp rockers. I have a set of Harland Sharp rockers in my GOAT though.
    Cromwell, CT
    Quote Originally Posted by lo-lyf View Post
    Carlin Sharps are the best!! It was George Carlin's rocker arm company he started after he made his fortune with "Thomas the train"
    The harland sharps are similar quality to the carlins but with a lower performance anodizing color
    01 ecsb 5.3 4x4 z71
    Avalanche 17s and a pant load of miles
    61 Corvette
    350, 4 speed, 4.56's
    32 Ford 4 door sedan
    keeping it "stockish"
    Racoon Twp., PA
    If you copied and pasted this, somebody needs to to a ABC check. Poor grammar in a for sale ad = mowronn.......yes, purposely spelled wrong.
    2013 CC 5.3
    81 C10 LS1 project
    spring, texas
    If your gonna shop on Craigslist than get use too "poor grammar". He might have a stroker motor, but just doesn't know what it takes to do it. Then again, he might of gotten screwed or is just an idiot......
    He is an idiot. I just notice the 6.2L and "Cast Iron" in the same sentence. "2006" doesn't help either.
