Results 1 to 10 of 10
Thread: djm front LCA question
    Jul 2009
    GA
    so i put the djm lower control arms on(4''), well it seems like it isnt lowered all the way, there isnt a way to adjust them is there? to lower the front any more? or maybe it didnt do exactly correct? any help would be great thanks
    [CENTER]
    KandN INTAKE
    44 SERIES FLOWS DUMPED
    SUPERCHIP(UH)
    4/7 LOWERED
    18'' TITANS
    got any pictures of before and after? I have used the 4" and now im running 3" and I noticed a difference pretty immediately
    wichita falls, tx
    are you sure the springs are seated in the spring buckets all the way?
    Intro Radicalli's
    Wichita KS
    mine went lower than expected...im thinkin of actually of going back up a tad, just cause our roads suck here
    2006 Trailblazer SS RWD
    McConnell AFB, Wichita, KS
    ya something doesnt wound right? have you checked if everything seated correctly?
    2005 SS AWD, 22" REPLICAS, VOLANT CAI, MAGNAFLOW EXH, 1/2 DROP- NEXT: TUNE, SHIFT KIT, SERVOS, TRU-COOL
    (SOLD)2000 ECSB HARLEY DAVIDSON EDITION. 2''/4" DROP, 20" BUDNIKS, COWL HOOD, MOLDED ROLLPAN, CLEARS, DROP IN K&N, MIT, TAYLOR WIRES, LOUDMASTER EXHAUST
    1991 RCSB S10 355 SBC, 700R4, 8.5" 10-BOLT, 18"/19" C6 Z06 WHEELS, 4"/5" DROP, MAGNAFLOW DUALS W/X-PIPE, FULLY SHAVED W/ CADDY LIGHTS: NEXT-LSX 370/PT88/TH350
    The Garage
    Quote Originally Posted by banker099 View Post
    +1 If the spring is not fully seated in the spring pocket, it will not be as low as it should be
    Jul 2009
    GA
    heres a before and after, lmk if this looks 4'' to yall
    before
    [IMG][/IMG]
    after
    [IMG][/IMG]
    [CENTER]
    KandN INTAKE
    SUPERCHIP(UH)
    4/7 LOWERED
    18'' TITANS
    Jul 2009
    GA
    would the sway bar end links have anything to do with it? the springs look to be seated right
    [CENTER]
    KandN INTAKE
    SUPERCHIP(UH)
    4/7 LOWERED
    18'' TITANS
    You really should do you photos in the same location. One place you're on level ground and the other looks like you have the left front compressed on a hill or something. Doesn't look like a flat 4" drop, though.
    here is my 4" in the front with the DJm for comparison. You might be running a tad taller tire then me though
