Results 1 to 10 of 10
Thread: come to a halt
    Jun 2003
    Smile
    ok i put her in{by myself} --houston we have a problem. my converter bolts do not line up. as a matter of fact they are around a 3/8 inch off. here is a pic of the flywheel and verter. also they are only using three of the six holes. did i miss something? does anyone have the part number for the flywheel for the flexplate from when they did there swap. if so i need it real bad.
    :bang:
    04 supercrew 5.4 3 valve-magnaflow catback
    formerly 02denali 12.79@107
    Apr 2003
    Mansfield, Texas, USA
    Did you get it figured out yet?
    The bolt pattern for the LS1 torque converter is different than a standard bolt pattern. I could not use the flex plate from a 2002 V8 van that had a 4L60E. I guess they use the stardard turbo 400/350 bolt pattern along with the 4L80E. The flex plate will not clear the back of the block without a spacer unless they make a flywheel specifically for a LS1 type engine to 4L80E.
    Jun 2003
    there are two different types of flexplates for the 6.0's. the flexplate for a 60e is recessed in the middle not allowing an 80e verter to seat in the middle. i got it fixed already.
    Apr 2003
    Cool deal, now waiting for the driveshaft I guess?
    Jun 2003
    yoke and driveshaft are in process. coulple a more little projects to finish to.
    San Marcos Texas
    Sorry if this is a repeat question but what driveshaft did you go with? I'm thinking about getting a new one and was wondering what is the best one to go with?
    Jun 2004
    george west texas
    when you gonna have it on the road lance
    '13 silverado LT...stock
    '11 lt 4x4 z71..tvs1900
    Jun 2003
    im still using my stock tewo piece. i am having the front part shortened. and the new yoke along with a new front u joint.
    im hoping to have her on the road by this weekend or early next week.
    When i swapped the 80E in my truck, i had to get a different U-joint and yoke, but i didnt have to shorten the driveshaft at all......
    2000 Silvo 5.3L, 4L80E, 6" Fabtech lift (bad idea) , 33's, K&N, Gibson headers, Magnaflow Exhaust, HD Hood, JBA plug wires, 4.10's w/auburn posi, radix'd
