Results 1 to 10 of 19
Thread: 85 El Ko with 04 LS1 & 4l60e Swap. HELP
    Oct 2009
    Question 85 El Ko with 04 LS1 & 4l60e Swap. HELP
    I just finished stuffing a LS1 & 4L60e trans into my 85 El Camino.
    Had the new computer married to old harness so my stock gauges would work.
    The dude that did the work was Oscar Perez Hot Rod Controls.
    I later found out that he is a flake. So I am looking for some help and advise to finish the things he never did.
    Fortunely the truck runs great and is driveable.
    But the tach and speedo don't work and I need to install the smog equipment and get it register in Ca.
    Before the CHP stops me and tows it out from under me.
    You know they take that unregistered vehicle thing very seriously.
    So if anyone can tell me what smog equipment I need and how to get the
    tach and speedo working I would greatly appericate the help.
    The engine ia out of and 2004 GTO.
    Thanks,
    Joe
    Racoon Twp., PA
    Using Mechanical Speedo i presume?
    Check these guys out. Scroll down for Cable X.
    Speedometer Gear, Speedometer Gears, Ford, GM, Dodge 700R4
    2013 CC 5.3
    81 C10 LS1 project
    What's the rule for vehicle age in Cali when you no longer have to go through smog checks? 25 years? You're there!
    If not, you're almost there anyway because the 2004 GTO doesn't have smog pumps or EGR if I remember correctly. All you have to plumb in is the fuel vapor (evap) canister and solenoid.
    Dakota digital makes speedo equipment for conversions.
    Sorry to hear you met the infamous Oscar Jaurez/Perez.
    Oct 2009
    Man that was fast. Thanks for the reply.
    No they changed it to 30 years.
    Is the solenoid the little electirc valve under the fuel rail.
    I am sorry I met him too. He was no great bargin. I still owe him about $125.
    surprised he hasn't been in touchj with me.
    Thanks,
    Joe
    If he still owes you work then you don't owe him money.
    Yeah, thats the solenoid. The vapor hose should be routed to your old charcoal canister. Hopefully you still have that since it is a Cali car.
    Oct 2009
    I kept all the calif smog stuff. That should be easy enough.
    I still owe him for parts. So I thought he would stay in touch.
    Oct 2009
    Looked at your truck. It looks great.
    You have done alot of stuff to it.
    Bet it hauls ass!!!!!!!!!!!!!!!
    Oct 2009
    Northern California
    Quote Originally Posted by JJ62 View Post
    Thanks,
    Joe
    Just to let you know they got rid of the rolling thirty any vehicle year 1976 and newer has to have a smog inspection. I your still unsure about your swap you can talk to the referee in your area and they can help you with any questions since they're the ones that have to inspect your vehicle and give your your engine swap placard.
    this site should be very helpful to you. esp. when dealing with the LS, try maliburacing.com's forum also
    Psalms 144:1
    Si vis pacem, para bellum
    Oct 2009
    Hey Red,
    Is that PCM Red module #10 wht wire my
    tach wire. I was looking at your other post and I think it maybe the same as my
    PCM. You have been more help then any site I have been on.
    Thanks Joe
