Results 1 to 10 of 11
Thread: camaro ls1 manifolds into 73-87 trucks
    Aug 2009
    has anyone used ls1 (98 -02) camaro manifolds in a 73-87 c10 truck if so what if any mods did you do???
    Jun 2007
    tulsa, oklahoma
    i used them and had to cut the collector on the driver side to angle it into the center more, had to trim the frame rail on the pass side about 1/2 inch for the length of the collector to keep it from rubbing. they do work but not just a bolt on deal. i used long tube headers, i realized you are talking about the stock manifolds, sorry
    1987 jeep wrangler, 1999 LS 1, 4l60 231j transfercase, dana 30 frontend ford 8.8 rearend 3:73 gear ratio. sandersons shortie headers, 2.25 inch exhaust into 3 inch flowmaster muffler.
    Aug 2006
    I had some on my 86, they work, just need to grind pass side down some so it does not rub frame.
    I've got a set already to go in my garage...I went with headers.
    86 C10 6.0/4l80e
    Aug 2009
    Quote Originally Posted by pcmcobra View Post
    ok so if i used the direct fit short headers that are on ebay that claim to bolt up the the factory collectors on a camaro they should just about fit ???
    I remember Beatertruck had a set of Fbody LS1 long tube headers in his square body truck.
    Aug 2009
    i was under the impression that the camaro headers were narrower than the truck my 5.3 truck manifold has the EGR on the PASS side and hits right where the bolts conect to the crossmember on the frame rail and also hit at the rear where the collector bolts some grinding required there to the frame !!! i would run non EGR monifolds and mod the frame at the rear but i want something with a note!!!
    so im looking into those block hugger headers they are shortys but im afraid that they will hit where the EGR on the truck manifolds are hitting now!! if the camaro manifolds fit then i would think the block huggers might clear aswell !!
    Hurley, Mississippi
    What brand are your headers?
    '86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
    Aug 2009
    Quote Originally Posted by HarleyDave View Post
    no i dont have any!! im still looking for a set cant seam to get a answer on what will fit!!!
    Aug 2006
    my s&p headers fit perfect
    86 C10 6.0/4l80e
    Aug 2009
    brought some new aftermarket truck shortys today see how they go they UPS them to me, they fit a 99-04 truck have to remove the EGR mount of the side im sure but at least they are no cast iron so welding to be fine!!!migght have to clear the PASS frame alittle !!
