Just got done a few minutes ago dropping a 2005 5.3 from an Avalanche with 4L60E in my 1981 K5 Blazer 4wd.
Used 1" forward plates. With those plates 4l60e with tranfer case adapter is 1/2" forward of position that the 305 with th350 and adapter was.
The stock manifold fit with 1/2" x 3/4" grind on passenger side to add a little room to manifold heat shields.
Fit without grind but was a little close
Need to cut front crossmember or notch it. Cut mine as I will make one up out of tubing that wraps around front of motor.
Other than a little mod on tranfer case crossmember as it is old long adapter style and I am using the new short height adapter. This motor was built to fit this truck.
I will take pictures soon and post them..
